MK3S parts
gatonini@zoominternet.net
(@gatoninizoominternet-net)
MK3S parts
I'm just wondering how many parts changed from the MK3 to the MK3S beside the y axis. and extruder. Motor holders etc ? Thanks Gary
Napsal : 20/02/2019 12:38 am
Sembazuru
(@sembazuru)
Re: MK3S parts
The announcement just mentions the y-axis belt retention under the bed carriage. The tensioning for MK3S is done there instead of hanging the idler mount from the front plate as is done in the MK3.
It isn't clear yet (because no one has gotten their upgrade kit from Prusa yet) if the y-axis tensioning plastic parts will arrive with the upgrade kit. But from what I've seen those parts (two pieces) don't seem to be in the archive of .stl files for "this is what is new so you can print your own parts".
See my (limited) designs on:
Napsal : 20/02/2019 12:54 am
Re: MK3S parts
I was referring to z axis motor holders and z axis tops I think they also redesigned the enisy box .
Napsal : 20/02/2019 1:32 am
vintagepc
(@vintagepc)
Re: MK3S parts
I don't see any striking differences in the 3S repo and they are still marked R3 or R2.
Napsal : 20/02/2019 1:50 am
Sembazuru
(@sembazuru)
Re: MK3S parts
My bad. I didn't see that you mentioned the y-axis in the OP.
Napsal : 20/02/2019 2:03 am
Markster911
(@markster911)
Re: MK3S parts
From what I could see in the MK3s part repository there are 4 y-axis parts marked R4 ... but these are not part of the MK3-to-MK3s upgrade STL-repository (if you know what I mean, in that zip-file there are just extruder parts included).
MK3 kit B7-R3 / custom FW v3.5.1 with 7x7 MBL
Slic3r PE v1.41.2
Napsal : 20/02/2019 7:46 am
