MK3s not booting, factory reset not working after failed firmware upgrade
ZBM2
 ZBM2
(@zbm2)
After a failed firmware upgrade, my printer is stuck at "Original Prusa i3 Prusa Research ..." and won't go any further.
Attempting to perform a factory reset in accordance with https://help.prusa3d.com/en/article/factory-reset_2216 doesn't change any indications.
Postato : 05/06/2020 10:21 am
ZBM2
 ZBM2
(@zbm2)
RE: MK3s not booting, factory reset not working after failed firmware upgrade
I never did get it to factory reset. But throwing all the USB B cables I had out and replacing them with a new one did allow me to successfully flash the firmware, which solved all the problems.
Postato : 08/06/2020 6:45 pm
@sean-s27
Thanks for the information! Many flash problems are caused by unsuitable, too long or defective usb cables. The factory reset should work without usb cable.
Happy printing!
Postato : 08/06/2020 10:31 pm
Ryan Kratz
(@ryan-kratz)
will not boot or flash
I am having the same problem of it being stuck on the opening screen "Original Prusa i3 Prusa Research" screen.  I tried to flash the firmware to fix it, but it failed multiple times.  It was printing fine earlier today.   I turned it off and then when I turned it back on later, it is stuck.  I tried holding the button down for a factory reset, but it does nothing.
Postato : 24/08/2021 3:51 am
Utenti
failed firmware
Posted by: @ryan-kratz
I had this issue and had to install the firmware 5-6 times to get it right.  If you feel that will not work, I would try a firmware downgrade.  If that does not work, contact support via eShop Chat.
Postato : 24/08/2021 9:39 am
