MK3S+ MMU2 Turns Off
Eddiie
(@eddiie)
My MK3 has worked fine for a few years.   Recently I turned it on, printed something, after the print it sat idle for about 15 minutes.   It then turned off even though the power switch is still on.   I flip it off, back on,  on/off real quick, unplug it for several hours, plug it back in, turn it on and it works again...   Send a print job and about 1.5 hours into it, the printer turned off again.
How do I begin to troubleshoot this?   A new power supply from Prusa is freaking $100.00!  Are you kidding me?  If it was that great, it would not have failed.
Could this be a failing stepper driver?
Publié : 19/09/2022 8:33 pm
Membre
RE: MK3S+ MMU2 Turns Off
I would contact support by chat on this one.  You do not need to buy from them, but they can help direct you to the problem.
Publié : 29/09/2022 10:48 am
