MK3S+ life cycle?
Ray of Hope
(@ray-of-hope)
MK3S+ life cycle?
I was shopping for some spare parts for the mk3s+ and find the hotend is "out of stock."   Does the out of stock part indicate a fading of support?  What does the support life cycle for this model look like?  Is there a suggested 3rd party replacement?
  https://www.prusa3d.com/product/assembled-hotend-mk3s-2
Opublikowany : 22/11/2024 7:29 pm
Ray of Hope
(@ray-of-hope)
RE: MK3S+ life cycle?
I asked support if the parts would come available and they said most likely they would not.  There's a chance some might bubble up.  They said support for the model is waning.
Our culture look at the past as what is behind you. Others look at the past as what is in front of you, since you can see it.   In that culture, you can't see the future, so it's considered behind you.  Here we are, we have landfills.
I'll try this one from amazon:  FYSETC Prus i3 Hotend MK3S+ J-Head Extruder Kit 24V 40W for 1.75mm Direct Filament Compatible with Prus i3 MK3/MK3S/MK3S+
Opublikowany : 24/11/2024 12:55 pm
