MK3S Hotend removal
Gołąb
(@golab)
MK3S Hotend removal
Hello,
my hotend jammed and I wanted to remove it to clean it. Unfortunately all tutorials I find are for MK3 (like this one - got me 83% through but I cannot do point 6). How do I remove the hotend itself? It seems to be enclosed more then in previous verision.
Here is a photo where I am now:
Thanks in advance 🙂
Postato : 02/03/2019 6:39 pm
Martin Wolfe
(@martin-wolfe)
Re: MK3S Hotend removal
You have to remove the motor cover plate from the extruder body to free the hotend for removal. So as a result the idler door has to be removed as well introducing the pain of trying not to loose the nylon washers.
Regards,
Martin
Martin Wolfe
Postato : 02/03/2019 6:52 pm
Gołąb
(@golab)
could you please also show that in a picture or elaborate a little more?
Do you mean screws from picutre 31 from this guide? https://manual.prusa3d.com/Guide/5.+E-axis+assembly/1055?lang=en#s18573
Postato : 02/03/2019 7:01 pm
vintagepc
(@vintagepc)
Utenti
Regards,
Martin
The 3S doesn't actually use those washers anymore. I was surprised when I did the upgrade.
Postato : 02/03/2019 7:03 pm
Martin Wolfe
(@martin-wolfe)
Yes step 31 needs to be undone along with 21 and 14.
Strange about the nylon washers being one existant now.
Regards,
Martin
Martin Wolfe
Postato : 02/03/2019 7:20 pm
Gołąb
(@golab)
Worked perfectly! Thank you people for help!
Postato : 02/03/2019 7:59 pm
