MK3S Error - Check Y axis length
Plasma Ecto
(@plasma-ecto)
hello,
printer has been working wonderfully since I got it in February.  I recently put together my MMU and got ready to install it.  I found out I need to make my enclosure taller to fit the MMU.
I didnt unplug anything, adjust anything, move anything. I went to print and it fails stating check axis y length.
So I reset printer to factory settings, check belts, move plate, all is smooth, nothing catching.
same error when I run self test and belt test.
If I take the heated bed off, unscrew 9 screws and take it off, no error. Its just the carriage on the y axis and belt.
So that led me to believe something is getting caught or causing drag to stepper motor and throwing error.
again manually moving it, the heated bed cable doesn't catch on anything, doesn't even come near anything.
I have already pulled every bit of hair out and am now bald.
Please help me with this error!!
Publié : 04/09/2020 3:28 pm
