MK3S constant reboot with USB
Twice today after printing from the card I connected the USB cable, the MK3S goes in a non-stop reboot loop with or without the SD card inserted?
Postato : 12/01/2020 12:15 am
RE: MK3S constant reboot with USB
The USB Cable initials an reset when plugin, but only once a time. This is necessary for flashing the firmware, but it should not reset in an endless loop. Change the USB cable. Why did you connect the USB cable. Are you using a Raspberry or similar device?
Postato : 12/01/2020 1:53 pm
Topic starter
answered:
@karl-herbert
Will try a new USB cable. I am connecting the printer to my PC.
Postato : 12/01/2020 2:03 pm
Try turning the printer off before inserting the USB cable.
Postato : 12/01/2020 10:22 pm
