MK3s callibration issues after long term usage
Printer worked fine and suddenly wanted me to callibrate the axis. When I am doing it, it crashes against the end of the axis.
It seems not to sense the end correctly. I don't know why. Did some of you also run into this problem?
Thanks in advance
Napsal : 17/02/2022 1:05 pm
In your case I would clean and lubricate the smooth rods then try an XYZ calibration.
Napsal : 17/02/2022 3:44 pm
Topic starter
answered:
RE: MK3s callibration issues after long term usage
I phoned the support, after some trial and error, I downgraded the software 2 versions below and voila it worked again. It is the MK3s with the old silver power adapter.
Napsal : 31/03/2022 2:53 pm
