MK3s built a few weeks ago - Printer fails mesh calibration
Ohm
 Ohm
(@ohm)
My printer is failing mesh calibration at point 43 quite often (Some problem encountered). It's always at that point. When it works, it seems to work consistently - but when it doesn't, it fails consistently. It may be coincidence, but it usually works if I have it calibrate just before attempting mesh bed leveling. My numbers look to be quite consistent though - I'm not seeing drift of any sort with each calibration cycle. From what I can tell, all of my numbers look good. I made it through 3/4's of a spool before having any problems at all. When it prints, everything looks absolutely perfect. I've attempted raising the small black covers on the Z axis motors a bit, tightening the X axis belt, and using the nylock mod to level the bed.
Printer info is:
3.7.0-2201
EINSy_10a
Apr 1, 2019
Y from min - Left: 11.53, Right: 11.48
Skew: 0.04 deg
0;0 offset X = -0.15, Y = 1.03
Belts X = 283, Y = 278
I tightened the X belt quite a bit (2 notches), but it didn't change my X number much (Was around 287 if I recall). I could tighten it more, but it's already a mid-tone guitar string... which seems about right, if not even a tad too tight.
G81 shows near +- 0.05 across the bed
Recv: 0.07167 0.04167 0.02917 0.02833 0.00583 -0.01333 -0.01250
Recv: 0.06667 0.04000 0.00583 -0.01500 0.00667 0.02417 -0.00167
Recv: 0.06917 0.03917 0.00750 0.01104 0.02500 0.06667 0.04333
Recv: 0.04333 0.01833 -0.01083 0.02667 0.03708 0.06333 0.07417
Recv: 0.06583 0.03167 0.00250 0.01312 0.03333 0.07833 0.07333
Recv: 0.03917 0.01917 -0.00583 -0.01000 0.02333 0.05833 0.02083
Recv: 0.00917 -0.00583 -0.01667 -0.02333 0.01833 0.03583 0.02833
Additionally, I can't figure out how to access the live chat for Prusa. I think my account may be out of sync - they came out with prusaprinters.org right after my printer was delivered, and I now seem to have two accounts (same e-mail on both, but different passwords bewteeen prusa3d and prusaprinters). I get no orange chat button showing on shop.prusa3d.com, but they do show my printer as "Shipped". Any help there would be much appreciated.
Publié : 03/05/2019 9:49 pm
Vojtěch
(@vojtech)
RE: MK3s built a few weeks ago - Printer fails mesh calibration
1. The belt tension numbers only change after you do a self-test. Ideal numbers are reported to be under 270, but I don't think belt tension is a problem here.
2. When I had failed calibrations, lowering the PINDA probe in the mount helped.
3. Contact them HERE. Hopefully that will work for you.
Publié : 03/05/2019 9:58 pm
1 personnes ont aimé
Ohm
 Ohm
(@ohm)
Thanks Vojtech. I'll try lowering the probe a tad and run back through the setup again (after my current print completes... in 5 hours). If that still doesn't do the trick, I'll go the support route. The page you pointed me to does in fact take me to their contact page.
Much appreciated!
Publié : 03/05/2019 10:15 pm
