Mk3s+ after firmware upgrafe 3.14.0 - Raspberry P Zero is not working anymore
Austria777
(@austria777)
Hi Folks,
is anyone knowing if there are issues with firmware 3.14.0 and Raspberry pi Zero (direct connected on the board).
My setup is no longer working. I cant connect anymore to Octoprint on the Raspberry. Nothing changed, did only a firmware flash on the Prusa.
Any tipps ?
BR. Werner
Respondido : 08/08/2024 3:44 pm
AutoDrone
(@autodrone)
RE: Mk3s+ after firmware upgrafe 3.14.0 - Raspberry P Zero is not working anymore
Sure, here’s a more natural and flowing version:
Hey @Austria777, I’m facing the same issue. Initially, when I installed 0.8.1.img on my PI ZERO 2 W, everything worked fine. However, I needed to update my printer firmware to 3.14.0. Then, I made a mistake and thought it would be a good idea to enable SSH on my PI, so I reflashed it with SSH enabled. Now, I can’t connect to WiFi or ping it because it doesn’t get an IP address. I keep getting the “No LAN” message. I tried reversing everything, but I’m still getting the “No LAN” message on my printer. Any help would be appreciated!
AutoDrone
Respondido : 12/09/2024 4:41 pm
