Mk3s+ after firmware upgrafe 3.14.0 - Raspberry P Zero is not working anymore
Hi Folks,
is anyone knowing if there are issues with firmware 3.14.0 and Raspberry pi Zero (direct connected on the board).
My setup is no longer working. I cant connect anymore to Octoprint on the Raspberry. Nothing changed, did only a firmware flash on the Prusa.
Any tipps ?
BR. Werner
RE: Mk3s+ after firmware upgrafe 3.14.0 - Raspberry P Zero is not working anymore
Sure, here’s a more natural and flowing version:
Hey @Austria777, I’m facing the same issue. Initially, when I installed 0.8.1.img on my PI ZERO 2 W, everything worked fine. However, I needed to update my printer firmware to 3.14.0. Then, I made a mistake and thought it would be a good idea to enable SSH on my PI, so I reflashed it with SSH enabled. Now, I can’t connect to WiFi or ping it because it doesn’t get an IP address. I keep getting the “No LAN” message. I tried reversing everything, but I’m still getting the “No LAN” message on my printer. Any help would be appreciated!
AutoDrone
