MK3 y-axis linear bearing clicking noise- Solved (!?)
tarpus91
(@tarpus91)
After about 10 hrs of usage, my new MK3S+ printer (kit) started making clicking noises during y-axis moves. The noise was kinda like flicking a soda can. It got worse over time and eventually it was clicking several times during each y-axis movement. I lubed the bearing and re-adjusted the rods, but that was only a temporary fix as the clicking would soon return. The rod ended up with a black greasy buildup near the ends and several scratches in the middle.
Prusa sent me a new y-axis rod and bearing kit. After installation using the y-axis adjustment procedure, all seemed well   After about 10 hours of usage, the clicking noise started up again.  Ugh.
I used a caliper to measure the parallel distance between the y-axis rods at the front and back. They differed by 0.01inch despite having repeated the y-axis rod holder setup procedure. I removed the front right plastic rod holder and filed away some of the plastic on the "knob" that sticks down into the structural rail. I figured this would give more freedom of adjustment to allow a better setup procedure.
This did the trick, and after the y-axis setup procedure, the parallel distance between the rods matched front and back, and the clicking immediately stopped. An imperfection on the fwd/RH plastic rod holder had been keeping the setup procedure from working properly.
Hopefully this will be a long term solution!
Lessons learned-
1) New bearings don't click, despite being out of alignment. They will click later when they are worn in.
2) It would be good to measure the parallelism of the y-axis rods during the assembly and setup procedure.
3) If they are not parallel, follow the procedure outlined above to tweak the fwd RH plastic rod holder.
Cheers!
Respondido : 13/04/2022 6:08 pm
RE: MK3 y-axis linear bearing clicking noise- Solved (!?)
Thanks for the update.
10 thousandths of an inch, is not a large deviation. but as you have shown. it obviously makes a difference.
(Just being nosey) did you use vernier calipers to measure? or are you lucky enough to have a monster size Micrometer?  or something else?
Respondido : 14/04/2022 10:20 am
tarpus91
(@tarpus91)
I used a cheap 6 inch digital caliper that resolves to 0.01 inch. The caliper is unable to reach between the y-axis rods (~6.25 inch), so I supplemented the reach with a small polished plastic cube. The setup worked well enough to tell me that the rods were not parallel and that I needed to investigate why.
Now that I think about it, an imperfection in either the front RH or front LH plastic rod support clamp would cause the rods to not be parallel. I just focused on tweaking the RH clamp to correct the situation.
Respondido : 14/04/2022 4:43 pm
Cheers, I was wondering, because my vernier won't open that large either!
for a ten yhou difference it probably doesnt matter which side you adjust
Respondido : 14/04/2022 8:04 pm
