MK3 wont restart after filament outage
ben.g16
(@ben-g16)
My MK3 (S upgrade) stopped in the middle of a 4 hr print when the filament ran out.  There was no way to restart the print with new filament, there was no menu item.
Is there something in settings I don’t have right?
Dieses Thema wurde geändert Vor 7 years von ben.g16
Veröffentlicht : 03/09/2019 8:45 pm
RH_Dreambox
(@rh_dreambox)
RE: MK3 wont restart after filament outage
Under Settings menu, check that Filament sensor is On and F.autoload is On.
Veröffentlicht : 04/09/2019 10:43 am
ben.g16
(@ben-g16)
 I have never been able to get filament autoload to work.  It just sits there, even when the temps are up.  Just tried a print from beginning. Stuck the filament in, pressed autoload and waited.  Extruder & bed heated up and it started the print process - with no filament feed.  The filament was still where I stuck it in.  I had to kill the print, turn off autoload, load the filament, then restart the print.
Whats missing?
Veröffentlicht : 05/09/2019 6:26 pm
Dave Avery
(@dave-avery)
you IR sensor is not working or disabled
Veröffentlicht : 05/09/2019 11:34 pm
