MK3+ rebooting
bstadtler
(@bstadtler)
MK3+ rebooting
I have a 2 month old MK3+ that when trying to connect to Octoprint the printer reboots and I can not connect. Just started 1 day ago.
I bought it pre-assembled and it had been working fine. so I'm at a lost.  Maybe the board has gone bad. What do you think?
Veröffentlicht : 06/12/2022 9:35 pm
Probably a loose connection, unplug and reinsert all the plugs on the electronics boards.  Are you connecting by usb? If the problem persisits try a different cable.
Veröffentlicht : 06/12/2022 10:23 pm
bstadtler
(@bstadtler)
RE: MK3+ rebooting
Its printing from the SD card right now. I will try both of those tomorrow. see what Happens
Veröffentlicht : 06/12/2022 11:07 pm
bstadtler
(@bstadtler)
RE: MK3+ rebooting
I figured it out finally I had RPi raspberry pi switched on in the settings. Turned it off and problem was gone. I was trying to adjust the Z setting and must have clicked when I should have clacked. Thanks for the help
Veröffentlicht : 11/12/2022 4:53 pm
