MK3 Not Reponding
Yngeinstn
(@yngeinstn)
MK3 Not Reponding
Greetings,
Up until today I haven't had any issues with Pronterface or any other programs connecting and then executing the .gcode. Today i tried to print and I am getting no response from the MK3. It connects and I am able to reset via the software but it doesn't execute a single command i.e Home -x-y axis or anything. I tried factory reset of the printer and a complete uninstall of the software and then reinstalled. It seems to be having the same issue with Cura and Simplify 3D.
Any suggestions would be helpful. As it stands, i am dead in the water until i can get a usb SD card reader to put the files on it and try to print. Side note when i 'Print From SD Card' with any of the preloaded files it works.
Thanks for your help.
Respondido : 11/11/2018 6:40 pm
Re: MK3 Not Reponding
It sounds like you've narrowed it down to the USB interface and drivers. Fixing that is likely to be very OS-specific. Can you provide more detail on what OS you're running Pronterface under?
Respondido : 11/11/2018 7:45 pm
Peter in Katy
(@peter-in-katy)
Check to see if you've accidentally enabled RPi.
An hour with support (drivers, cables etc) got me nowhere. I tried to lower the z-axis through the menu, and voila! RPi Port enabled. Turned it off, and good to go.
Respondido : 11/11/2018 11:39 pm
Yngeinstn
(@yngeinstn)
Thanks for the quick response. Yes this morning it I was thinking it was usb cable but i thought how would it be able to reset the MK3 but not start the print.. I am running Windows 10...
Respondido : 12/11/2018 3:13 pm
Yngeinstn
(@yngeinstn)
peter.k42,
I am not sure what RPi is, can you please elaborate?
Respondido : 12/11/2018 3:14 pm
peter.k42,
Raspberry Pi.
Respondido : 12/11/2018 3:39 pm
Yngeinstn
(@yngeinstn)
bobstro,
You sir, are a genius. I would have never known if it wasn't for you.. It fired right up..
Thank you
Respondido : 12/11/2018 9:25 pm
