MK3/MMU2 upgraded to MK3S/MMU2S resets just as it wants to load the filament.
[Solved] MK3/MMU2 upgraded to MK3S/MMU2S resets just as it wants to load the filament.
jd14
 jd14
(@jd14)
I received my upgrade kit a while back but finally had time to do the upgrade.  I upgraded the firmware on the printer to:3.7.2-2363, MMU2 to:1.0.2-132.  I sliced with PrusaSlicer-2.0.0-win-201905201652.  I ran through the  calibration on the printer again, z axias calibration/first layer, x/y/z bounds, etc.  All worked well.  When I print, it works normally until it tries to load the filament.  It heats, x/y point calibration, then moves to the point it extracts filament before printing.  As soon as it gets there, and moves to the built plate, the printer reset/reboots.
I've sliced multiple times, same thing.
Any idea what is wrong or what I can check/upgrade/etc?
Posted : 01/09/2019 10:43 pm
jd14
 jd14
(@jd14)
RE: MK3/MMU2 upgraded to MK3S/MMU2S resets just as it wants to load the filament.
As a test, I did a preheat for ABS and left it for 5 minutes.  No reboot.
Posted : 01/09/2019 10:53 pm
jd14
 jd14
(@jd14)
Solved my problem, I had the MK3S settings in slicer, not MK3S MMU2S
Posted : 01/09/2019 11:47 pm
