MK3/MMU2 upgraded to MK3S/MMU2S resets just as it wants to load the filament.
I received my upgrade kit a while back but finally had time to do the upgrade. I upgraded the firmware on the printer to:3.7.2-2363, MMU2 to:1.0.2-132. I sliced with PrusaSlicer-2.0.0-win-201905201652. I ran through the calibration on the printer again, z axias calibration/first layer, x/y/z bounds, etc. All worked well. When I print, it works normally until it tries to load the filament. It heats, x/y point calibration, then moves to the point it extracts filament before printing. As soon as it gets there, and moves to the built plate, the printer reset/reboots.
I've sliced multiple times, same thing.
Any idea what is wrong or what I can check/upgrade/etc?
RE: MK3/MMU2 upgraded to MK3S/MMU2S resets just as it wants to load the filament.
As a test, I did a preheat for ABS and left it for 5 minutes. No reboot.
Solved my problem, I had the MK3S settings in slicer, not MK3S MMU2S
