MK3 Extruder Squeaking/Sizzling
isaac.s3
(@isaac-s3)
I just assembled my MK3 kit yesterday. There is an annoying squeaking and sizzling when the bondtech gears move during printing, which occurs on and off. It has not affected the print quality. The gears appear to be aligned and clean. I have tried adjusting the idler tension with no success. Has anyone else experienced this issue?
Opublikowany : 17/07/2018 1:08 am
Christizzz
(@christizzz)
Re: MK3 Extruder Squeaking/Sizzling
i am having the same issue...did you find a solution ? thanks
Opublikowany : 15/10/2018 10:59 pm
