MK2.5S -> MK3S+ upgrade
Zura
 Zura
(@zura)
Hi All, between a friend and I we had enough parts after buying the heated bed and einsy board from Prusa for me to upgrade my MK2.5S up to a MK3. Everything went well and I was able to calibrate it just fine. The problem that I am trying to solve is that the Y axis seems to be inverted. These are the original steppers that came with my MK2 back when I bought it. Did the Y direction change between the MK2 and the MK3? Which wire pair should I change to get the direction to go the correct way? All 4 steppers have the wires arranged Blue Red Green Black from top to bottom when plugged into the Einsy.
Thanks in advance!
Best Answer by Milos V.:
if you take a look to the available spare parts, stepper motors are still identical for MK2 and MK3. So it should not be in motors as such.
Take a look to the 3D model of both printers. The Y axis motor is mounted from the right side in MK2 and from the left side on MK3. So definitely there has to be a change in FW to swap the rotation direction. So have you uploaded correct firmware? Try to make the factory reset prior to FW reloading as well.
Napsal : 21/01/2021 10:20 pm
Milos V.
(@milos-v)
RE: MK2.5S -> MK3S+ upgrade
Napsal : 22/01/2021 8:57 am
1 lidem se líbí
Zura
 Zura
(@zura)
@milos-v
Wow! I feel INCREDIBLY stupid for not checking that... I was going down a whole other path entirely! Thank You so much!
Napsal : 22/01/2021 12:03 pm
