MINTEMP error bed
Dude
 Dude
(@dude)
MINTEMP error bed
Hello,
I am having an ongoing MINTEMP error bed while printing. I have a I3 Mk3s and it is about 18 months old. It has not had heavy use. The printer will preheat quite fine and the temperature readings are normal. The printer will then go through its levelling routine and start to print. At some point in the first 5 minutes the error will occur and printing stops. The issue first occurred about a week ago 18 hours into a 30 hour print.  Any advice on what I need to do to repair this please?
Thanks
Respondido : 25/02/2021 12:45 pm
RE: MINTEMP error bed
Posted by: @dude-4
Hello,
Thanks
Hello and welcome to the Prusaforum!
If the ambient temperature is not too low (newest FW below 10 °C ), it is possible that the wiring harness (voltage and thermistor) from the print bed to the einsy board has a loose contact. This happens frequently. The lines become brittle over time and must be replaced.
Maybe you will find a good tip here as well: https://help.prusa3d.com/en/article/mintemp-error-and-mintemp-bed_2169
Respondido : 25/02/2021 2:03 pm
