MINTEMP BED error, emergency stop called.
IbPalle
(@ibpalle)
Just a quick post before I start taking things apart. Getting the MINTEMP BED error and emergency stop afterwards. All cables are secure and I tried wiggling bed thermistor cable quite a bit while preheating and wasn't able to induce any errors. Thermistor cable is secure in the Einsy board afaict.
Next I'll take the heatbed power cable cover off and check everything there is seated correctly but was wanting to ask here if there are other factors I should consider. I have read the KB in the MINTEMP errors.
Publié : 31/08/2021 7:54 am
Dan Rogers
(@dan-rogers)
Time to order spares, eh?  All it takes is a momentary loss in contact - which you cannot measure.  MINTEMP BED means change the thermistor cable on the bed.  It takes about 20 minutes with very minimum disassembly.
Publié : 01/09/2021 11:14 am
