MINTEMP BED error and other weird stuff happening
javier.r9
(@javier-r9)
Hello,
I've had my printer for about eight months and it had been working perfectly until yesterday. I've recently been receiving the MINTEMP BED error consistently and cannot print anything. I have gone through the steps detailed in Prusa's help page on MINTEMP errors.
Whenever I try to print, I am usually able to get all the way through the 9-point calibration. When preheating, the screen will read out the correct values for the bed and nozzle (e.g. Nozzle: 215/215 and Bed: 60/60). However, as soon as it finishes the 9-point calibration, I get the MINTEMP BED error and the target temperature numbers drop down to 0 degrees (e.g. Nozzle: 215/0 and Bed: 60/0). At this point, the temperature just keeps dropping and the print percent completed reading increases about 1-3% every second despite not printing anything.
I have tried resetting, checking to see if the thermistor is attached firmly, checking my wiring, and flashing different updates (from 3.5 to 3.7). At first, I thought that the issue could be the thermistor wearing down since I did see that jump to zero but it happens too consistently to be that? Has anyone had this problem before? Would the random percent completion ("finishing" a 12 hour print within a minute) and the MINTEMP BED errors be related?
Veröffentlicht : 04/07/2019 6:28 am
RE: MINTEMP BED error and other weird stuff happening
Sounds like bed thermistor plug loose or wire fractured
Regards Joan
Veröffentlicht : 04/07/2019 3:27 pm
Phoenix Down Labs
(@phoenix-down-labs)
The exact same thing is happening for me. Let me know if you figure out what the deal is!
Veröffentlicht : 09/01/2020 12:14 am
Lorenzo
(@lorenzo-4)
RISPONDI: MINTEMP BED error and other weird stuff happening
Oh this problem started today with me, exactly as javier's.
Have you solved the issue? And how? 🙂 thanks!
Veröffentlicht : 03/01/2023 4:07 pm
