Min Bed Temp error
kenji.c
(@kenji-c)
Min Bed Temp error
Hello, it seems the last 5 prints, 2-3 of them have failed because of a "min bed temp" error. The black cable sensor that is going to the heatbed (not the 2 power cables) seems to be the issue, if I wiggle that cable, the red light starts flashing again like it's working correctly. But if I let it go, the red light stops flashing. I noticed the main cable coming from the printhead/extruder also pushes on the heatbed cable coming out, im wondering if that is wearing down the cable. I may try to redesign the plastic piece that sits here and have it bend downwards instead of out the back (pic here: ). Anyone else have similar? What was the fix?
Postato : 03/07/2018 2:49 pm
kenji.c
(@kenji-c)
Re: Min Bed Temp error
I made this piece, it extends longer and can go out toward the right side, will test once I figure out my cable issue
Postato : 03/07/2018 3:36 pm
Steve
(@steve-2)
Did this solve the problem? I am getting the same error message. It seems to be a connection issue for me, as well, though i cannot spot where it is occurring.
Postato : 11/04/2019 1:22 pm
