Marlin k-factor generator Prusa Edition Download.
NickRno77
(@nickrno77)
I’m trying to create a Linear Advance GCODE to calibrate LA for a 0.8mm and 1mm Nozzle.
I can’t work out how to download the JS and HTML files for the Prusa Version of the LA Generator. When I right click there’s no download. Any ideas please?
https://github.com/3d-gussner/MarlinDocumentation/tree/Prusa/_tools/lin_advance
https://www.prusaprinters.org/prints/39968-la15-k-factor-calibration
“If you have custom printing profiles and you want to generate your own LA15 K-factor values visit the community Marlin k-factor generator Prusa Edition and download at least all '*.js' and the 'k-factor.html'. You can open the k-factor.html in your local browser and enter your values. This is based on Marlin k-factor generator with Prusa specific G-codes and settings.”
Ce sujet a été modifié il y a 5 years par NickRno77
Publié : 22/01/2021 9:56 pm
RE: Marlin k-factor generator Prusa Edition Download.
It's nice to have pre-generated versions I suppose, but I find it easiest just to create my own on the Marlin site. It will generate a gcode file with the correct parameters that you can just download directly and print.
Publié : 22/01/2021 10:07 pm
NickRno77
(@nickrno77)
Posted by: @bobstro
I thought this was the same as the Marlin Generator but tweaked to work with PRUSA ?
Publié : 22/01/2021 10:25 pm
If it is the same, use the one that works. I think the version on PrusaPrinters just has pre-generated versions.
Publié : 22/01/2021 11:21 pm
