MAINTENANCE - How to know when and what to replace
JP91306
(@jp91306)
Mitglied
I am a totally new user here, so this question may have been answered many times.
I am using the factory build verison of the i3 MK3S+ and only printing with PLA for now as I learn to use the machine and the software. Everything is working properly right now.
I understand that, eventually, I will need to replace the brass nozzle, and perhaps the the printing plate as well.
How will I know when those times come. What do I watch for as indicators that replacement is needed?
Thanks for any time you have to offer answers and suggestions.
Veröffentlicht : 25/04/2023 8:52 pm
Stefan
(@stefan-3)
RE: MAINTENANCE - How to know when and what to replace
Hello,
nozzle wear is a continuous process and so there is no clear limit when to consider a nozzle to be worn.
If you only print PLA for now, i would not think about nozzle wear. You should be able to print many PLA spools with one brass nozzle.
Printing "glow in the dark" or fiber reinforced materials require a hardened nozzle!
Other maintenance:
  • Grease the linear rods with super tiny amounts of the Prusa grease. There has to be a thin film of grease always on the rods.
    Redistribute the grease that is pushed aside with your finger from time to time. The small tube of Prusa grease may last a year or so.
  • Do not grease the threaded Z-rods. It is not recommended.
  • Print the "Tension Meter for the GT2 belts of i3 MK3S+ or Prusa MINI+"   from Prusament PETG. It is the best tool to get the belt tension right.
    Correct belt tension is one of the most important things in my opinion.
    https://www.printables.com/de/model/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
  • Keep the fan blades clean from dust and filament stringing.
Basically, thats it to keep the machine running for a long time without serious damages  😀
Veröffentlicht : 26/04/2023 4:59 pm
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
Veröffentlicht : 26/04/2023 11:15 pm
JP91306
(@jp91306)
Mitglied
Thank you, that is just exactly the info I needed.  I know machines require care to work properly, and I want to be sure this one continues to do so.
jp
Veröffentlicht : 27/04/2023 12:21 am
