M112 Called - Emergency Stop - Thermal Runaway Protection
Strona 1 / 3
jurassic73
(@jurassic73)
So I've replaced my thermistor three times now on my MK3s which I've had for a year and I continue to get this after some time.  I got a solid year out of my printer before this started.  My blower fan was starting to get noisy so I replaced it with a Fystec.  A little while later I started getting the thermal runaway code and replaced my thermistor.  The block gets hot enough to cause the filament to boil before it fails with the M112.  Got a few good prints and then errors again.  Repeated this a few times and I'm wondering if something else is needing replacement.  I've verified the screw holding the thermistor is tight but not too tight to crush the thermistor.  I got my replacements from Filastruder.
Is the rambo in question?
I've run PID calibration with each new thermistor.
What else to check?
MK3s / My IKEA Lack enclosure
Opublikowany : 18/09/2020 5:15 pm
jurassic73
(@jurassic73)
RE: M112 Called - Emergency Stop - Thermal Runaway Protection
Tried to print again.  It was preheating and then this happened.  The filament was hot enough to boil on the hot end at which time I hit reset.  The heater block is getting hot, the temp reading is not working right it seems.  If the thermistor is good (kinda odd I'd have three go bad in a row), can the rambo be having issues?
Opublikowany : 18/09/2020 5:31 pm
This is a problem between the Prusa and Octoprint.  It is fixed in an upcoming firmware.
Opublikowany : 18/09/2020 5:59 pm
jurassic73
(@jurassic73)
@charles-h13
Thanks for the reply.  Do you know if there is a temporary fix?  Can I rollback my firmware?
Opublikowany : 18/09/2020 6:37 pm
@jurassic73
I did a hard reset and that sometimes fixes it.  What filament are you printing?
Opublikowany : 18/09/2020 7:18 pm
jurassic73
(@jurassic73)
Posted by: @charles-h13
@jurassic73
hard reset = power cycle?  I have done this to no avail.  Thanks for the suggestion.
I am printing with the generic PLA profile in Prusa Slicer.  Odd thing is I printed a PETG item last night just fine, 30 minute print.  I did update to the latest firmware(3.9.1) now to try to troubleshoot but still having the same problem.
Opublikowany : 18/09/2020 7:31 pm
jurassic73
(@jurassic73)
Saw this in the 3.9.1 notes but seems my attempt to run this firmware didn't help unless there's a compliment to this update in octoprint?
[quote]
Octoprint causing M112 fixed
The previous firmware versions sometimes incorrectly dropped some parts at the start of communication while connected over a serial line. This resulted in a scenario, where for example the Octoprint evaluated the printer as unavailable and sent G-code M112, which is a full emergency stop. More about the G-code M112 in our article at help.prusa3d.com.
This issue is now fixed and the printer communicates properly over the serial line.[/quote]
Opublikowany : 18/09/2020 7:35 pm
jurassic73
(@jurassic73)
Odd that this dives after the temp change from 1st layer to 2nd...
Opublikowany : 18/09/2020 7:39 pm
@jurassic73
No, hold the selector down while power on.  That fixes it for a few days to weeks.
I have had nearly no problems since uploading one printer to the new RC firmware.  It has nearly always been with PETG, ABS, and PC Blend.  I do nto understand it.  It never happens without printing from USB or SD card.
Opublikowany : 18/09/2020 8:01 pm
@jurassic73
Are you sure you updated to 3.91 - that is the RC and not the active firmware.
Opublikowany : 18/09/2020 8:03 pm
jurassic73
(@jurassic73)
@jurassic73
Ah - thanks and done.  Trying to print again now.
prusa3d_fw_MK3S_3_9_1-RC1_3512.hex is what I installed.
Opublikowany : 18/09/2020 8:21 pm
jurassic73
(@jurassic73)
No dice.  Tried to slice and set all layers to same temp, pukes at layer change still.  Odd.
Opublikowany : 18/09/2020 8:37 pm
I tried.  It seems a few folsk are hevign this problem for different reasons.  I can't udnerstand it.
Opublikowany : 18/09/2020 9:32 pm
jurassic73
(@jurassic73)
Thanks for your help.  Whittles down the troubleshooting 'logic'!
Opublikowany : 18/09/2020 9:46 pm
@jurassic73
True.  I must have been drunk typing that.
Opublikowany : 18/09/2020 10:15 pm
jurassic73
(@jurassic73)
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/prusa-slicer-pla-print-fan-speed-causes-thermal-runaway/
Interesting... about fan kicking on.  I had no issues printing PETG last night.  PLA today however has been a pain.
Opublikowany : 18/09/2020 10:45 pm
@jurassic73
Great info
Opublikowany : 18/09/2020 10:56 pm
jurassic73
(@jurassic73)
So I think I'm getting somewhere... I turned the fan down to 76/255 via the control knob and the graph is relatively flat.  I did install this fan after my stock one started making a lot of noise.
https://www.amazon.com/FYSETC-Cooling-50x50x15mm-Radiator-Accessories/dp/B07NTKG9K4
Looks like it pulls more current than the stock MK3s blower fan which is .28A and this new fan pulls .35A so I assume just a more powerful fan.  Will see how this print turns out and if I need to see if my cooling shroud has any damage or the like with air leaking up into the thermal probe area.  I do have my block in a silicon sock already.
Curious if those spikes are due to the shape of the print sending air back up into the thermistor probe.
Opublikowany : 18/09/2020 11:29 pm
Please keep us updated.
Opublikowany : 19/09/2020 12:07 am
jurassic73
(@jurassic73)
Worked on this more last night.  Here's a video of the temp fluctuations.
I even witnessed the temp fluctuation during bed leveling.  Stayed at 225/210 for a bit.
I had fired up a print, let it get to layer two when the cooling fan turns on to see fluctuations in temp, then turned the fan speed down from 255/255 to 100/255 and temps leveled out at 210 for a few minutes then went wonky again jumping around.
I find it hard to believe that three thermistors in a row would go bad in short time.
This all started after I swapped out my cooling fan.  This cooling fan is sold on a number of sites as a replacement for the stock blower fan.  I can't imagine jumping up from a fan that uses .28A to one that uses .35A would cause issues even since I slowed the fan speed and this happens.
When I install a new thermistor, things are good for a while then eventually get like they are now.
Is there a way to debug the Rambo unit?
Opublikowany : 19/09/2020 4:07 pm
Strona 1 / 3
