M112 Called - Emergency Stop - Thermal Runaway Protection
So I've replaced my thermistor three times now on my MK3s which I've had for a year and I continue to get this after some time. I got a solid year out of my printer before this started. My blower fan was starting to get noisy so I replaced it with a Fystec. A little while later I started getting the thermal runaway code and replaced my thermistor. The block gets hot enough to cause the filament to boil before it fails with the M112. Got a few good prints and then errors again. Repeated this a few times and I'm wondering if something else is needing replacement. I've verified the screw holding the thermistor is tight but not too tight to crush the thermistor. I got my replacements from Filastruder.
Is the rambo in question?
I've run PID calibration with each new thermistor.
What else to check?
MK3s / My IKEA Lack enclosure
RE: M112 Called - Emergency Stop - Thermal Runaway Protection
Tried to print again. It was preheating and then this happened. The filament was hot enough to boil on the hot end at which time I hit reset. The heater block is getting hot, the temp reading is not working right it seems. If the thermistor is good (kinda odd I'd have three go bad in a row), can the rambo be having issues?
This is a problem between the Prusa and Octoprint. It is fixed in an upcoming firmware.
@charles-h13
Thanks for the reply. Do you know if there is a temporary fix? Can I rollback my firmware?
@jurassic73
I did a hard reset and that sometimes fixes it. What filament are you printing?
@jurassic73
hard reset = power cycle? I have done this to no avail. Thanks for the suggestion.
I am printing with the generic PLA profile in Prusa Slicer. Odd thing is I printed a PETG item last night just fine, 30 minute print. I did update to the latest firmware(3.9.1) now to try to troubleshoot but still having the same problem.
Saw this in the 3.9.1 notes but seems my attempt to run this firmware didn't help unless there's a compliment to this update in octoprint?
[quote]
Octoprint causing M112 fixed
The previous firmware versions sometimes incorrectly dropped some parts at the start of communication while connected over a serial line. This resulted in a scenario, where for example the Octoprint evaluated the printer as unavailable and sent G-code M112, which is a full emergency stop. More about the G-code M112 in our article at help.prusa3d.com.
This issue is now fixed and the printer communicates properly over the serial line.[/quote]
Odd that this dives after the temp change from 1st layer to 2nd...
@jurassic73
No, hold the selector down while power on. That fixes it for a few days to weeks.
I have had nearly no problems since uploading one printer to the new RC firmware. It has nearly always been with PETG, ABS, and PC Blend. I do nto understand it. It never happens without printing from USB or SD card.
@jurassic73
Are you sure you updated to 3.91 - that is the RC and not the active firmware.
@jurassic73
Ah - thanks and done. Trying to print again now.
prusa3d_fw_MK3S_3_9_1-RC1_3512.hex is what I installed.
No dice. Tried to slice and set all layers to same temp, pukes at layer change still. Odd.
I tried. It seems a few folsk are hevign this problem for different reasons. I can't udnerstand it.
Thanks for your help. Whittles down the troubleshooting 'logic'!
@jurassic73
True. I must have been drunk typing that.
Interesting... about fan kicking on. I had no issues printing PETG last night. PLA today however has been a pain.
@jurassic73
Great info
So I think I'm getting somewhere... I turned the fan down to 76/255 via the control knob and the graph is relatively flat. I did install this fan after my stock one started making a lot of noise.
https://www.amazon.com/FYSETC-Cooling-50x50x15mm-Radiator-Accessories/dp/B07NTKG9K4
Looks like it pulls more current than the stock MK3s blower fan which is .28A and this new fan pulls .35A so I assume just a more powerful fan. Will see how this print turns out and if I need to see if my cooling shroud has any damage or the like with air leaking up into the thermal probe area. I do have my block in a silicon sock already.
Curious if those spikes are due to the shape of the print sending air back up into the thermistor probe.
Please keep us updated.
Worked on this more last night. Here's a video of the temp fluctuations.
I even witnessed the temp fluctuation during bed leveling. Stayed at 225/210 for a bit.
I had fired up a print, let it get to layer two when the cooling fan turns on to see fluctuations in temp, then turned the fan speed down from 255/255 to 100/255 and temps leveled out at 210 for a few minutes then went wonky again jumping around.
I find it hard to believe that three thermistors in a row would go bad in short time.
This all started after I swapped out my cooling fan. This cooling fan is sold on a number of sites as a replacement for the stock blower fan. I can't imagine jumping up from a fan that uses .28A to one that uses .35A would cause issues even since I slowed the fan speed and this happens.
When I install a new thermistor, things are good for a while then eventually get like they are now.
Is there a way to debug the Rambo unit?
