Long ABS print, large surface, may have damaged surface PEI sheet
bmsleight
(@bmsleight)
Similar to this, https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/pei-powder-coating-damaged--t19062.html#p88895
But much more noticeable ?
After a 12 hour ABS print, with large footprints.
Smooth surface PEI sheet, have some mark exact matching the ABS footprints. Where the ABS has warped and lifted a little of the bed, looks like the tense of the ABS may have damaged the smooth PEI Sheet. I can feel the noticeable bump no on the shert.
First timing with a long ABS print, all other prints have been PLA.
Photos: https://imgur.com/a/EODpwYS
Any advice ?
* Do not print large ABS
* Only short (timesie) prints ABS ?
* Although big bubbles - ignore them for now they will go way
Regards,
Brendan
Postato : 30/09/2018 12:56 pm
ron-f
(@ron-f)
Re: Long ABS print, large surface, may have damaged surface PEI sheet
Postato : 30/09/2018 4:00 pm
Tom
 Tom
(@tom-35)
Hello
I had exactly the same experience this WE.
Large ABS footprint left small bubbles and also seemed to have difformed the sheet. You can feel slight variations on the surface.
Questions:
- Does anyone know if we should avoid large print with ABS on those sheets?
- Do the coarse PEI coated sheets perform better?
Thanks,
Thomas
Postato : 01/10/2018 1:35 pm
bmsleight
(@bmsleight)
Some bubble still there after 6 months
Postato : 22/04/2019 12:44 am
Utenti
Some will go away, and some will stay. Print beds do not last forever; they are expendable.
Postato : 22/04/2019 1:32 am
Martin_au
(@martin_au)
Yep. Sometimes bubbles will stick around. ABS tends to be bad for many buildsheets due to it's requirement for high adhesion, and high warp tendency. Try Printbite+ or Filaprint if printing lots of ABS type materials.
Postato : 22/04/2019 6:56 am
