Let's discuss the control board
DavidR
(@davidr)
Some digging has shown me that the i3 MK3 uses a EINSY RAMBo control board.
While I Have found a detailed description of the RAMBo 1.4 1.3L (see image below) I can't find any details on the EINSY RAMBo board.
My question, referring to the image above, is does the EINSY board have the control ports for 2 hotend heaters and two extruder (E0 and E1) stepper drivers?
If so, is it possible to use a 3rd party dual hotend/extruder setup like two E3D Titan extruders and an E3D Chimera+ hotend?
I am aware of the MMU and of the nice advances (purge/wipe to infil, create a purge/wipe object other than a block, etc), and am willing to consider that as an option, but I like options. 🙂
Former Ender 3 owner.
Opublikowany : 01/08/2018 2:08 am
Peter L
(@peter-l)
Re: Let's discuss the control board
The version of the RAMBO used on the MK3 does not appear to have plugs for a second extruder.
If you look at step 8 on this page of the assembly instructions https://manual.prusa3d.com/Guide/8.+Electronics+assembly/513?lang=en you can see a photo of the version in the MK3. It looks significantly different from your picture.
Opublikowany : 01/08/2018 2:19 am
DavidR
(@davidr)
Thanks for the info. Darned shame, though. I don't have my Prusa yet. I'm returning my Ender3 tomorrow, never going with a Bowden design again.
FWIW I did a price comparison, the MMU is cheaper than the option I suggested.
Looks like I'm going to have to build the printer after the Prusa to get what I want. There are some nice options on OpenBuilds.com
Opublikowany : 01/08/2018 2:29 am
vernon.b
(@vernon-b)
https://github.com/ultimachine/Einsy-Rambo and https://ultimachine.com/products/einsy-rambo-1-1
#1 No, only has a single extruder output, no 5th driver for a second extruder
#2 Only has 2 high power FET controlled outputs, one for the heated bed, one for the single extruder. The other 2 MOSFETs for fans are lower current rating and also on the 2 pin connectors with 5V.
While I guess one could hack together an external MOSFET and external stepper driver carrier, and use custom firmware and connect those to the expansion headers, that's a lot of work. Again, while technically possible, it requires, something like these 2 parts, additional wiring, and custom firmware to map the new outputs.
Opublikowany : 01/08/2018 2:31 am
the prusa i3 mk2 uses Rambo Mini
the Mk3 uses Einsy
as far as I can see neither has scope for a second extruder in standard setup,
Prusa did create a four port expander / multiplexor option for the Multi Material Unit v1, on the mk2 printer using additional ports on the unidentified connector to the right of thr LCD / GPIO connectors, in the mini rambo picture above
there was no scope for a second heater with MMUv1
Opublikowany : 01/08/2018 2:36 am
Nikolai
(@nikolai)
Where do you see the benefit using EINSI board for a dual extruder customization? At the end you will not be able to use original Prusa firmware out of stock.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 01/08/2018 7:08 pm
frak.n
(@frak-n)
I have a Prusa MK3S and was wondering where there was an unused pin (or three) that I could use on the controller to control some LED lights via GCODE. Any help would be greatly appreciated.
Opublikowany : 07/04/2019 6:54 pm
gorillamotors
(@gorillamotors)
RE: Let's discuss the control board
Posted by: joan.t
the Mk3 uses Einsy
Joan,
Does the Prusa have a proprietary Einsy board or can I order one of the einsy 1.1a boards off the internet? I don't plan on multi materials at this time.
Jim
Opublikowany : 30/04/2019 1:03 pm
Vojtěch
(@vojtech)
To my best knowledge MK3's all shipped with unmodified Ultimachine Einsy Rambo 1.0a and later versions, including the latest 1.1a. But then, I thought the heatbreak was also a standard E3D v6 until recently.
Opublikowany : 30/04/2019 1:16 pm
jim.l5
(@jim-l5)
Posted by: frak.n
If there are indeed unused pin(s), it would be neat if the firmware designates a pin to indicate when operator intervention is required.  This would be so useful, for example, to interface with a flashing light that is visible across a large, noisy workshop.
Opublikowany : 01/05/2019 2:28 pm
jfedor
(@jfedor)
Posted by: frak.n
You can use some of the pins that are there for connecting the optional Raspberry Pi Zero. Here's a blog post that shows how to use them for triggering a camera to do a timelapse:
https://blog.prusaprinters.org/how-to-create-beautiful-3d-print-timelapse-videos/
You can indeed control the pins via G-code.
Opublikowany : 01/05/2019 6:28 pm
rogerinhawaii
(@rogerinhawaii)
What pins are indeed free on the EINSY RAMBo board??
Looking at the board pic and comparing it to the actual CPU, it looks like there are quite a few free pins.
But which ones are genuinely free and a available to be used via GCode pin control?
Opublikowany : 03/02/2024 2:50 am
