LCD screen concern
Imaginativ3D
(@imaginativ3d)
LCD screen concern
Hello anyone know what is wrong with the LCD screen? This just started happening today.
my MmU is having issues pulling the filament back when it is done.
Thanks.
Opublikowany : 06/11/2021 6:59 pm
sturzi
(@sturzi)
This happened to me also
This happened to me also several days ago. I switched the printer off and on and it turned back to normal. Since then it hasen't happened again.
Opublikowany : 06/11/2021 7:03 pm
Imaginativ3D
(@imaginativ3d)
That is what I been doing.  It does work afterwards but I'm just wondering what the reason is.
Is it a firmware bug or something?
Or is there a bigger concern?
Opublikowany : 06/11/2021 7:54 pm
It's much more likely to be a loose connection.  Try pulling and reseating your LCD plugs at both ends.
Opublikowany : 07/11/2021 12:21 am
Imaginativ3D
(@imaginativ3d)
RE: LCD screen concern
Will check that out. Thank you.
Opublikowany : 07/11/2021 1:34 am
Patrick McNamara
(@patrick-mcnamara)
Most of the times that my printer does it, I can hear the "snap" of a static discharge as I touch the printer.  The LCD screen is relatively sensitive to static discharge and can garble the screen when it happens.  Generally, any action that causes a full screen refresh will return the screen to normal display.
Opublikowany : 07/11/2021 3:44 pm
Swiss_Cheese
(@swiss_cheese)
Check the Ribbon cable
This can also be cause by improperly bent or twisted Ribbon from the LCD.
Good Luck
Swiss_Cheese
The Filament Whisperer
Opublikowany : 07/11/2021 11:40 pm
