LCD Menu does not work anymore
Tatie Devouvres
(@tatie-devouvres)
Hello everyone!
I had to change my hot end and everything worked fine (I think).
But when I wanted to use my printer after the changing, the menu did not work:  when I press the knob it goes to the main menu but when I rotate it nothing happens (NB: the knob is clicking as it should do) : the menu stays on the "Info Screen".
I searched in the forums but did not find any problem like mine.
Perhaps something happened inside the Einsy case when I disconnected (or reconnected the hotted cables?).
Thank you for your help!
Respondido : 23/11/2022 7:26 pm
