LCD knob stopped working
MR.Luck
(@mr-luck)
Hi, the rotaryencoder button on the LCD panel has stopped working, the kit has been working perfectly for one and a half months however when I started the machine I can rotate the button but the klick does absolutley nothing. Could this be a faulty PCB for the LCD panel? I have tried to disconnect and reconnect the cables and all other things imaginable and as I said it did work correctly for about on and a half months. Is there anything else I should try or do I just reach out to prusa for a replacment part?
Thanks in advance
Lukas S
Napsal : 20/05/2018 7:54 pm
BobCollins
(@bobcollins)
Re: LCD knob stopped working
I had this exact same issue, contact support in chat, and take a video of the issue to send to them when they request it. Then once they confirm it in the video you send in, they will send you a new display which will fix the issue.
Bob
Napsal : 21/05/2018 3:25 pm
