LCD display not working (First time startup, kit)
RakeMakes
(@rakemakes)
Hi! (Accidentally posted this in the MK2 forum)
I recently bought and assembled a Prusa MK3 kit. Everything was running smoothly until I plugged it in.
The LCD display flickers once and then nothing.
I've checked the cables to many times to count, and they are correct.
I tried adjusting the contrast of the display but nothing happened.
I flashed the firmware to the latest version but again; nothing.
I wore an anti-static wristband throughout the entire assembly (even with the plastic parts) so I am at a loss.
Anyone have any idea of what to do?
Here´s a video of what it looks like:
https://drive.google.com/file/d/1BsJ10t ... sp=sharing
Opublikowany : 18/01/2019 8:12 pm
thrawn86
(@thrawn86)
Re: LCD display not working (First time startup, kit)
the display itself is pretty cheap and very sensitive to bad cables. support will likely have you replace it after running through a few steps with you.
Opublikowany : 19/01/2019 4:23 pm
