LCD board Schematics
Bigdogbro1
(@bigdogbro1)
Hi All,
I have been trying to locate schematics for the MK3 LCD Display board and the Einsy controller firmware source code and not having much luck. Could someone please provide a link for this information. I am aware it's on GitHub but I don't get into that neighborhood that often and don't know my way around.
Thanks!
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Opublikowany : 31/08/2018 2:35 pm
Olef
 Olef
(@olef)
Re: LCD board Schematics
Everything Prusa can be found here - https://github.com/prusa3d
Opublikowany : 31/08/2018 5:30 pm
doa
 doa
(@doa)
it's not Prusa specific, it's general reprap display controller. It's called 2004 LCD Smart Controller, you can add "reprap" word when googling for it.
with above you'll find easily what you need. for example it's homepage: https://reprap.org/wiki/RepRapDiscount_Smart_Controller
there's also full graphic 128x64px controller, don't' get mistaken with it
Opublikowany : 01/09/2018 12:23 pm
Bigdogbro1
(@bigdogbro1)
Thank you so much for the help!
Opublikowany : 01/09/2018 3:08 pm
Bigdogbro1
(@bigdogbro1)
I am finding that the signal information does not match up on the schematic of the LCD/SD card front panel when compared to the Einsy Rambo board schematic LCD & SD card P1 & P2 connector information. The first picture is the SD card portion on the front panel PCB.
Is this the correct schematics for the MK3 controller?
It is from the GitHub site.
Thanks for any insight
Opublikowany : 03/09/2018 5:30 pm
