Layer shifting on live print
Hello,
Our printer is shifting completely almost 2 to 3 mm in the middle of live print. Shifting is not unique. it happens in sometimes on x axis and sometime on y axis
We did all type of system driven calibration and checked mechanical component like belt, pully and screw rod. But still the issue continues, we are suspecting electronic parts issue.
We needed support to solve this issue.
Napsal : 28/05/2024 7:15 am
RE: Layer shifting on live print
Did you check the grub screws that hold the motor shafts? Did you contact Prusa Support?
Napsal : 28/05/2024 10:43 am
