Layer error
FGU Himmmerland
(@fgu-himmmerland)
Layer error
Anyone know why this has started to happen in all prints? It's calibrated fine and low prints are fine. I printed same print a few days back with no problem. It's Prusament PLA and everything is updated.
Regards Martin
Veröffentlicht : 25/02/2022 11:08 am
512MB
(@512mb)
RE: Layer error
You have layer shift on X, i would first start with this:
Looks like the layer shits are on X.
Have you cleaned the rods?
Used some Prusa lubricant?
Checked your X/Y axis motors and pulleys?
Check the tension of your belts?
No objects are in the way?
Nozzle is not too close?
Check bearings?
IF Motors are  getting too hot{
  Try Switched out to new motors
Veröffentlicht : 25/02/2022 11:51 am
FGU Himmmerland
(@fgu-himmmerland)
RE: Layer error
Thank you for your response. It seems to be printing perfectly until it gets to a certain height, then it gets out of alignment for about 1 cm and then returns to the correct alignment. I have seen no error in the motors, belts or bearings - the printer is only a couple of months old.
I'll try to make a quick print and see if I can see what happens when the error happens.
Thanks anyway 🙂
Kind regards Martin
Veröffentlicht : 25/02/2022 12:05 pm
512MB
(@512mb)
RE: Layer error
You could try doing a factory reset and then try again. Could be a firmware issue. Long shot.
Veröffentlicht : 26/02/2022 11:43 am
Make your next print this:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Let us know how you get on.
Veröffentlicht : 26/02/2022 1:19 pm
FGU Himmmerland
(@fgu-himmmerland)
RE: Layer error
The problem was in the filament roll. It was a brand new silver PLA Prusa but after a while the filament would cross itself and lock. The printer would either missprint or pull the filament apart. After fixing the roll it prints perfectly.
/Martin
Veröffentlicht : 01/03/2022 8:07 am
