Lack of documentation on what settings change in your sliced print when using the percentage adjustment via knob on LCD
BuzzAldrin
(@buzzaldrin)
Is there documentation somewhere on what exactly is changed in your slicer settings when you use the percentage adjustment via the knob while a print is running?
I am tuning some settings and being able to use that while a print is running would be nice, but I would like to know exactly what it is doing before trying to calculate new slicer settings using the percentage change.
Is it all the speed settings? What about acceleration/jerk? Does retraction speed also fall under what is changed?
Napsal : 06/03/2019 12:45 am
Sembazuru
(@sembazuru)
Re: Lack of documentation on what settings change in your sliced print when using the percentage adjustment via knob on
Good question. Here is a followup:
If I have settings in Slic3r PE that bump up close to the maximum flow rate (mm^3/s) like can happen on large areas of infill, will increasing the speed exceed the flow rate potentially leading to failed prints?
See my (limited) designs on:
Napsal : 06/03/2019 1:28 am
