Issue Unloading Filament
Razor
(@razor)
So I’ve had this happen a few times now. I’m unable to unload the filament without having to open the filament door and trimming a little fishhook off. This past time it happened with PETG, but it has also happened with PLA. While I can’t confirm, oddly it seems to happen more with Prusa filaments than others. Is this an example of heat creep?
I’m happy with the prints. No issues other than this.
Mini+MK3S+XL 5 Tool
Opublikowany : 02/01/2023 8:40 pm
Hello
(@hello)
RE: Issue Unloading Filament
what tempratures are you printing at and is your idler screw at the right tension
Opublikowany : 03/01/2023 5:22 am
zukpr
(@zukpr)
I've had exactly the same problem and posted about it a while back. I tried various things but what seems to work the most consistently is to gently tug on the filament while the motors are ejecting it and it comes out fine.
I'm guessing that the tip is a bit soft and if you don't pull it out right away it cools in a way such that it gets stuck.
Opublikowany : 03/01/2023 3:09 pm
Razor polubić
zukpr
(@zukpr)
Here's a link to my older question: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/having-trouble-unloading-filament/
Opublikowany : 03/01/2023 3:12 pm
Razor polubić
Razor
(@razor)
Posted by: @hello
I was using the stock Prusament profile, so 240º. The printer was "cold" when I unloaded, so the nozzle temp was set to the stock 230º. From my understanding you want the tension screw to sit about flush with the housing. Is this too loose/tight?
Mini+MK3S+XL 5 Tool
Opublikowany : 04/01/2023 2:13 pm
Razor
(@razor)
Posted by: @zukpr
Thanks for responding with the link. I thought I remembered reading it before, but couldn't find it. I may ultimately do what @RandyM9 recommended to do here. I don't own an MMU, but if I did I could never imagine it working with the filament doing this from time to time.
Mini+MK3S+XL 5 Tool
Opublikowany : 04/01/2023 2:22 pm
Hello
(@hello)
Maybe tighten it a. Bit so it's just in from flush that's sticking out a bit so I would tighten a little bit.
Opublikowany : 04/01/2023 6:52 pm
Razor polubić
Razor
(@razor)
Will definitely try that. Thanks.
Mini+MK3S+XL 5 Tool
Opublikowany : 04/01/2023 10:00 pm
Razor
(@razor)
Posted by: @hello
I didn't want to over tighten it, that can be just as bad.
Mini+MK3S+XL 5 Tool
Opublikowany : 05/01/2023 3:47 pm
Robin
(@robin)
It's probably the internal PTFE which is damaged/worn or not all the way in and secured by the collet. See: https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-assembly-and-first-prints-troubleshooting/the-hook-of-death/#post-621626
Opublikowany : 05/01/2023 4:03 pm
Razor polubić
