Is This Pinda2 Working or Not?
dkaustin
(@dkaustin)
I have been unsuccessfully trying to connect a Pinda2 probe to a non-Prusa printer.  So far, I have tried three different Pinda2's (one black tip, two gray tips) and NONE of them have worked.  I suspect that these are knock-offs, but, even so, 0 for 3 is a pretty poor record.  If I understand how the probe should work, I would expect that when the probe triggers, the black (signal) lead should go high (+5v) relative to ground.  On all three of the probes I have tried, there is no change on the black lead between triggered and non-triggered.
Are these probes defective, or do I completely misunderstand how the probe should work?  Help please.
Publié : 04/06/2022 10:41 pm
Membre
RE: Is This Pinda2 Working or Not?
Do the probes light when coming against the surface?
Publié : 05/06/2022 12:03 pm
