Is thermal error during hot tightening normal?
SG Newb Rider
(@sg-newb-rider)
I was changing my nozzle to a 0.6mm and doing a hot tightening at 280C, holding the heat block with a wrench and tightening the nozzle with a socket. When I tighten the printer goes into thermal error, starts beeping, and the temperature starts dropping. Is this supposed to happen? Thanks in advance
Napsal : 27/01/2023 3:52 pm
Kyle B
(@kyle-b)
RE: Is thermal error during hot tightening normal?
Yes, the wrench will soak up some of the heat and cool the heater block down causing the error to pop up. I just try to do it as quickly as possible to get it tight before it cools down too much.
Napsal : 27/01/2023 4:57 pm
Also, if you're using the latest firmware, go to the Hardware menu and use the Change nozzle option so the new thermal protection model (that I don't think anyone has asked for) gets disabled.
Napsal : 27/01/2023 6:46 pm
1 lidem se líbí
Kyle B
(@kyle-b)
I had forgotten about that feature.
Napsal : 27/01/2023 7:48 pm
