Is either of these noctura fans the same as the OEM part on the MK3
KLAUS
(@klaus-3)
I need a hot end fan for my prusa MK3, i found these two similar looking fans on amazon, Can some one tell me if either is the same as the OEM fan.  Can I use either of these will I need to change the conector? I have no electronic experience so I want to make sure I get the right one, I can put a new conector on as long as i know which wires go yo whic teminal.
Noctua NF-A4x10 5V PWM, Premium Quiet Fan with USB Power Adaptor Cable, 4-Pin, 5V Version (40x10mm, Brown)
here is the link to the above
https://www.amazon.com/dp/B07DXS86G7/ref=emc_b_5_i
OR
Noctua NF-A4x10 5V, Premium Quiet Fan, 3-Pin, 5V Version (40x10mm, Brown)
https://www.amazon.com/dp/B00NEMGCIA/ref=emc_b_5_t
Napsal : 11/07/2020 11:59 pm
CovertPluto3502
(@covertpluto3502-2)
RE: Is either of these noctura fans the same as the OEM part on the MK3
Both are the right size, but keep in mind that the OEM fan has a longer cable. You should get the 3 pin fan as the Einsy has 3 pins. You'll also need to crimp on some connectors, and extend the wires a fair bit. There are lots of images online to see the pinout of the fans.
This post was modified před 6 years by CovertPluto3502
Napsal : 13/07/2020 5:13 pm
Posted by: @bruce-h7
OR
If you do not want to solder anything or mount any plugs:
https://www.igo3d.com/original-prusa-hotend-fan-noctua-mk25s-mk3s
Napsal : 13/07/2020 6:16 pm
KLAUS
(@klaus-3)
I would have ordered from them but then only ship to EU.
If any one has any links for this fan and cable all set up for mk3, please list them , thanks
Napsal : 13/07/2020 8:06 pm
@bruce-h7
Maybe try this replacement: https://www.printedsolid.com/products/ldo-sunon-fan-mf40100v1-1000c-g99
https://www.ebay.com/itm/Sunon-V1-Hotend-Cooling-Fan-prusa-MK3-MK3s-5V-MF40100V1-1000C-G99-bear-upgrade/324180235480?hash=item4b7aa5d4d8:g:NZYAAOSwRB5c3yVP
https://www.amazon.com/-/de/2-Pack-Bearing-Extruder-Radiator-Printer/dp/B07W5VGVW2/ref=sr_1_1?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&dchild=1&keywords=mk3+hotend+fan&qid=1594672241&sr=8-1
Napsal : 13/07/2020 8:34 pm
KLAUS
(@klaus-3)
Thank you Karl very helpful!
Napsal : 13/07/2020 10:48 pm
