Intructions to replace hotend?
My hotend plugged up. I broke the heater wires in the process of trying to clean it. I have ordered a entire new replacement hotend. Is there some instructions on the best way to go about replacing this assembly or do I just start taking it apart in the reverse order as in the manual. I thought somewhere I came across a prusa guide for this procedure but I cannot find it.
Respondido : 18/04/2020 3:57 pm
RE: Intructions to replace hotend?
The Mk3 online assembly manual has good detail. I used it as a guide when replacing my hotend components. Just read each section and the notes carefully. Do make sure the version of the assembly manual you are viewing matches your printer.
Respondido : 18/04/2020 4:43 pm
