Installing mk3 software has killed my LAPTOP!
DrSnippers
(@drsnippers)
I downloaded and installed the Drivers software for my Mk3, when I re-booted my Fuji i3 Laptop Hanged Up; I had to Power OFF . My Win 7 Prof O.S. is now U/s , FUBAR Fcuked!
I'm using my Rasberry to MSG this....
The Repair disk hasn't worked, I've downloaded an Instal. disc and it has to FORMAT my HARD friging DRIVE GIGAloads-A-LOST DATA...,.
jVERY psssssd OFF!!
I've used Linux to salvage all my 3d print shit and music .·..
I HAVE desided to load Unbutie-sum-thing LINUX o.s. and dump WINDOWS ...
Will all the mk3 slicer stuf etc and C~URA for my A8 work????
CAN ANYONE HELLLLP ME!
Yours worried not 3d printed for a week...
Postato : 11/05/2018 4:58 pm
stahlfabrik
(@stahlfabrik)
Re: Installing mk3 software has killed my LAPTOP!
That is where a backup comes in handy.
Postato : 11/05/2018 5:52 pm
cindy.h3
(@cindy-h3)
My vote it ditch windows and go with Fedora 28.
Yes cura and slic3rPE, prusa control etc work in linux.
Good luck!
Jon
Postato : 11/05/2018 10:27 pm
stahlfabrik
(@stahlfabrik)
Exactly!
When windows me crashed on me killing all my files I converted to Debian for three years.
Then I got a Mac and never looked back. Since 13 years
Postato : 11/05/2018 10:41 pm
eric.d14
(@eric-d14)
Much of the data should be recoverable depending on if it's a corrupt OS file or a corrupted file system.
If you don't have access to another system and the data is important, consider trying a bootable liveCD Linux disc and see if it can mount the file system.
Regardless of what OS you choose to pursue, it would be wise to check the health of the system drive in case this was a symptom of failing storage media.
Postato : 11/05/2018 11:34 pm
Erik
 Erik
(@erik-3)
For future reference, the 9nly thing that would possibly kill Windows is a bad driver. If one gets installed and Windows won't boot you can enter recovery mode and load a Restore Point that Windows always saves before it installs drivers. No need to reload anything. If that doesn't work you may have just conveniently had a hardware failure during the installation.
Postato : 12/05/2018 9:13 pm
thrawn86
(@thrawn86)
No distro of Linux will save you from not having backups, or using a bargain bucket 5400rpm spinner to store critical data, faulty ram/psu, or even still using a 10-year old OS, all of which are likely scenarios for your laptop failing.
Installing slic3r didn't kill windows, sorry. Also, the earth is round and jetliners are not spraying chemicals into the air.
Postato : 12/05/2018 11:00 pm
stahlfabrik
(@stahlfabrik)
But climate change - that must be fake, right? Please?
Postato : 13/05/2018 10:07 pm
