In a calibration / reset loop
Guy Meyer
(@guy-meyer)
Mitglied
Hey all
I changed the nozzle on my MK3 and went to re-cal the first layer. My printer then reset itself before starting the first layer calibration tool! I figured no big deal, somethings bugged. I'll just use the wizard and get a clean set of calibration data. Same thing!
After a couple tries I thought maybe I could just do a standard XYZ calibration from the settings menu and hopefully that would unbug whatever was happening when I inevitably would do the first layer calibration. I was successfully able to do an XYZ calibration, but hit the same reset issue when I went to do the first layer calibration.
I even factory reset AND flashed the firmware
On top of all of this! It resets when I try to unload the filament. Video below to help illustrate the issue. Any help would be greatly appreciated.
https://www.dropbox.com/s/j1ojfixqvv7rimn/IMG_4150.MOV?dl=0
Veröffentlicht : 19/07/2019 1:20 am
Dave Avery
(@dave-avery)
RE: In a calibration / reset loop
had that happen when auto home fails.  make sure your print head cabling is all clear and not hitting anything
Veröffentlicht : 19/07/2019 12:59 pm
Guy Meyer
(@guy-meyer)
Mitglied
Yep, it's all clear
Veröffentlicht : 19/07/2019 4:16 pm
Guy Meyer
(@guy-meyer)
Mitglied
Took some photos, everything seems in place. The blue wire is a bit frayed at the end, but best I can tell is it's in the socket correctly. I don't see wires touching each other.
https://www.dropbox.com/s/oyd314sba3zd242/IMG_7291.HEIC?dl=0
?dl=0
?dl=0
?dl=0
Veröffentlicht : 19/07/2019 4:29 pm
