Identify which model MK3 I have
JK
 JK
(@jk)
How to tell if I have MK3 or MK3s?
Publié : 19/03/2020 3:29 pm
RE: Identify which model MK3 I have
Look at the Filament sensor board,if it is standing on it's edge near the filament you have a Mk3 with Laser Filament sensor,
If it is flat on the top of the extruder housing, with a cover over it, you have a Mk3S
this is a Mk3S with an extra 5 volt LED soldered onto the +5V pin and the Out Pin, on the Filament sensor, to give Immediate indication of the filament sensor status, without fiddling in the LCD Menu's
this is the Mk3S with the MMUv2S sensor stack, and extra LED...   the cover is back in place on this version...
Publié : 19/03/2020 9:55 pm
JK
 JK
(@jk)
mine has collar sticking up for filament feed and tops of two bolts. Does not look flat like yours. So I'm going with MK3.
THanks.
Publié : 20/03/2020 2:15 am
