How to lower load filament temp
Which files contain the nozzle temp limit when loading filament? I am using a material that melts lower than the 190 degree setting. Thanks all!
Postato : 17/04/2018 9:26 pm
Re: How to lower load filament temp
Preheat temps are static in the firmware. You can't change it (easily).
You can preheat manually by setting the nozzle temperature to your desired value. Once the temp is reached you can load the filament.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 18/04/2018 12:14 am
