How to fix this issue in the slicing software?
zoltan87
(@zoltan87)
Basically I have a major problem with my 3d printed parts collapsing on bridging sections, due to the slicing software using wrong print patterns. Please see the pictures in the link:
https://imgur.com/a/5a6xN1a
Any idea how to change print pattern on a given layer? I am amazed that the slicing software (PrusaSlicer) is not intelligent enough to detect it by itself.
Napsal : 06/09/2019 2:20 pm
RE: How to fix this issue in the slicing software?
Perhaps some of the part errors are misleading the software - but it looks like it's doing what it is supposed to do.  You might try increasing bridge flow to 100%.  You can also try changing the bridging angle - but 45 looks like it's best.
Can you modify the part so the smaller squares don't close until the next layer?
Napsal : 06/09/2019 6:22 pm
zoltan87
(@zoltan87)
Thanks for the suggestions. Unfortunately this is a very small part. and due to interlocking requirements with other parts I can't change the geometry even with just one layer. I will try out the bridge flow change and see if that improves things.
But just to make sure I understand it correctly: seems like there is no way in the software to to alter the printing pattern of a given layer? Because if I could change the way that problematic layer is being printed to the way the next layer above it is being printed, then all my issues would be solved. I am just so puzzled that there is no way to achieve this in a software like PrusaSlicer, as it seems extremely sophisticated and user adjustable in every other way.
Napsal : 07/09/2019 9:56 am
