How do I identify what model I have?
print_n00b
(@print_n00b)
Hello and sorry if this has been asked, but I can't see to find a clear answer.  Buddy of mine had a MK3 he was not using and let me borrow.  I wanted to update the firmware to latest and greatest, however, am not sure if this is the MK3s or MK3s+.  Is it possible to enter the serial number somewhere to check?  I'm guessing it is a MK3s since it has a the orange control knob instead of the black ones I'm seeing on the site, but would like to make sure so I don't accidentally load wrong firmware and brick something.
Thanks!
Opublikowany : 27/11/2022 3:28 am
RandyM9
(@randym9)
RE: How do I identify what model I have?
See @joantabb ‘s answer in this recent thread-
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-can-i-tell-which-version-of-a-mk3-i-have/
Cheers
Opublikowany : 27/11/2022 6:05 am
print_n00b polubić
For all intents and purposes there's no difference between the Mk3S and the M3S+ from a firmware perspective. The Mk3S and S+ are basically the same printer, with some minor upgrades. And if you or your buddy upgraded the Mk3S to a Mk3S+, it will still identify in firmware as a Mk3S.
Opublikowany : 27/11/2022 12:13 pm
print_n00b polubić
print_n00b
(@print_n00b)
Thank you. Just tried flashing. The lcd  on the mk3s said completed and firmware shows as latest, however the message on prusa slicer that I used to flash said failed. 🤷‍♂️
Opublikowany : 27/11/2022 4:52 pm
