Hotend won't heat
ryan.kipar
(@ryan-kipar)
Hotend won't heat
I had a print that created a huge ball around the end of the printer, so I had to replace the hot-end because it broke the wire.  I hooked up a new one and it heated up good the first time but now it won't heat anymore.  The connection is good and just stays at room temp.  I just replaced the fuses but nothing has worked so far.  Any ideas?
Publié : 01/07/2020 9:37 pm
