Hotend termistor replacement
Kvant
(@kvant)
Hi everyone,
unfortunately one of my print failed and significant amount of the filament covered the hot end around the extruder. Trough my attempt to remove the stucked filament, hotend termistor wires get ripped off.
So now I am looking for some appropriate replacement of the hotend termistor.
I've found here on this forum that the mk3 uses the 100K NTC thermister, but I don't know what to look for in the e-shops. Is there difference between mks termistors or are they all same? Should I just look "new cartridge style E3D v6 HotEnd termistor" or is there anything I should be aware of? Do you have any tips/links for the possible hotend termistor replacement?
Thank you for all answers.
Veröffentlicht : 06/07/2018 11:20 am
Re: Hotend termistor replacement
Hi Jifi,
I believe it is a Semitec cartridge thermistor.
different thermistors have different performance profiles, so it's a good idea to get the right one!
Veröffentlicht : 06/07/2018 12:49 pm
Zarsk
(@zarsk)
I ended up buying a need heater block that came with a thermostat on amazon. Getting the heater cartridge out with out destroying the heater block was very hard.
Veröffentlicht : 10/07/2018 8:44 pm
Michael K.
(@michael-k-2)
Why not just buying a 40W 24V thermistor from e3d?
Veröffentlicht : 11/07/2018 9:38 pm
Hi Michael,
I think you are a little confused,
the heater is rated in watts and voltage,
the thermistor is described by it's resistance... the same thermistor will work on the Mk2 and Mk3
https://e3d-online.com/thermistor-cartridge
https://e3d-online.com/v6-block-sock-kit
https://e3d-online.com/heater-cartridge-24v-40w
Veröffentlicht : 12/07/2018 1:33 am
Michael K.
(@michael-k-2)
You are right, I misread... confused? maybe sometimes 😉
Veröffentlicht : 12/07/2018 3:53 pm
J.R. Mode
(@j-r-mode)
RE: Hotend termistor replacement
So if my thermister wire has run its course and broke on me , where would be the the best place to get the whole hotend and heater block?
It didnt want to release the thermister wire and the whole heater block is in need of replacement as well. Oh yes, this is for a mk3s+. please someone send me a link to the correct hotend with heating block and new nozzle to boot, please?
Veröffentlicht : 12/07/2025 11:02 am
Artur5
(@artur5)
You'd have to say us where you live. No use recommending an American site if you are in Europe and vice versa.
Veröffentlicht : 13/07/2025 8:59 am
J.R. Mode
(@j-r-mode)
My bad I live in California so that would be the West Coast of America.
Veröffentlicht : 14/07/2025 11:05 pm
